Author Topic: ‘Defrost’ dash decal ...  (Read 2688 times)
Por911t4
« on: June 01, 2019, 14:50:23 »
Ok so this must be among the smallest of cosmetic details but I'm all about the small details ..... does anyone know if the ‘defrost’ decal (circled in yellow) is available as a reproduction anywhere ? Mine is missing . Thanks Barry
Por911t4
Re: ‘Defrost’ dash decal ...
« Reply #2 on: June 01, 2019, 15:06:15 »
Jeeez Jonny, Im new to the forum but once again the knowledge of the forum members never fails to amaze me ! Thanks very impressed
I’ll get it ordered .
Regards
Barry
mnahon
  • Canada, QC, Montreal
« Reply #3 on: June 01, 2019, 15:25:41 »
Barry, I think your car is a Euro spec car, and I don't think Euro cars had that badge.
Meyer
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #4 on: June 01, 2019, 15:44:34 »
If yours has a hole in where the defrost plate attaches then you need it. Otherwise the European version is correct. See pic
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
mbzse
« Reply #5 on: June 01, 2019, 18:28:16 »
Quote from: mnahon
Barry, I think your car is a Euro spec car, and I don't think Euro cars had that badge..../...
These plates at light switch and heat/ventilation levers on dash were factory fitted to US Pagodas only (e.g those that have code SA491 on body data plate).
See also this thread: https://www.sl113.org/forums/index.php?topic=29161.msg210898#msg210898
/Hans S
« Reply #6 on: June 01, 2019, 20:13:32 »
Hi Barry - If I am reading your stable list correctly your Pagoda is a 1966 230SL.  I can tell you that even the U.S. spec '66 230SL did not have those plates.  U.S. DOT safety and labeling regulations went into effect for the U.S. 1968 model year, so the earliest U.S. spec Pagoda with satin finish horn ring, thicker dash padding, soft door pockets, etc., would be a late U.S. spec 250SL.   Some of the safety and labeling regulations were phased in.  For instance, while side marker lights and front seat shoulder belts were required for 1968 model year vehicles, front seat headrests did not become mandatory until the 1969 model year.  When the headlamp and defroster labels were phased in would be and interesting subject for exploration.
My guess is that most folks who acquired a 280SL from the States and subsequently changed out the round headlamps for Euro lamps, deleted the side marker lights and maybe even went back to hard door pockets, probably left the light switch and defroster labels intact.  Their presence on the dash would be a dead giveaway to a knowledgeable observer that a car that otherwise appears to be a home market pagoda was actually originally a U.S. market car.
