Author Topic: need tips no how to unbolt the drive shaft from the rear axle  (Read 1894 times)
merrill
hello
in the process of trying to pull the rear axle
i am down to unbolting the 4 bolts from the drive shaft to the pinion input shaft, compressing the compensating spring, unbolting the hanger carrier, centering bolt and both shocks.
almost there
unfortunately i am stuck trying to unbolt the 4 bolts connecting the drive shaft to the pinion input shaft.  I have bent back the lock tabs but cannot keep the shaft from turning while un bolting the 17mm nut(s)
should i use the parking / e brake to hold the shaft in place while i try to unbolt the nuts using a box wrench?
also it seems that i can only access the nuts on the drivers side of the car between the 6pm and 10 pm position.
thanks in advance
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: need tips no how to unbolt the drive shaft from the rear axle
« Reply #1 on: June 03, 2019, 00:57:24 »
Set the emergency brake to keep the driveshaft from turning. Those skinny 17mm can be difficult. Try bumping them with an air tool first (air hammer with blunt drift).
merrill
« Reply #2 on: June 03, 2019, 12:53:44 »
Thanks Joe!
I will try you suggestion this weekend
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
« Reply #3 on: June 14, 2019, 16:54:14 »
got the bolts off!
it took more bumping from the air hammer than i thought it would take.  they were really on there
thanks Joe!
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
