My 67 SL had not been started for a month or so. I decided to take it out today and it would barely back out of the garage. The driveway slopes up coming out of the garage and when I got on the hill the car would not move. At one point the engine would not rev up although the pedal was pushed to the floor. I let the car drift forward a little and kept trying to move back and forth and it finally started to move. When the trans warmed up it pulled out fine the rest of the day.
The other problem is that I don't think it is shifting in to forth gear. At 60 mph the tach reads about 3700 rpm. Is this about right? I found a chart someplace that gave the rpm at different speeds but now I can't find it.
I did check the transmission fluid and it is at the proper level.
Any help and advice appreciated, Pete
