Author Topic: Horn rattle  (Read 1984 times)
mauro12
  • Italy, Sicily, Messina
Horn rattle
« on: June 08, 2019, 14:39:27 »
Hello guys, the horns of my car make a strange sound, like rattle. I would like to know how easy is the replace them and how to do it. Thank you
Mauro Pisani
250sl 1967 5speed zf manual
Re: Horn rattle
« Reply #1 on: June 08, 2019, 15:48:59 »
Does it rattle when you honk them?
kampala
  • USA, CA, Beach Cities
Re: Horn rattle
« Reply #2 on: June 08, 2019, 16:19:04 »
I assume you mean the Bosch horns in the engine compartment and not a common rattle on the horn ring (this also has a fix).   The Bosch horns come apart and can be reassembled with a new paper type gasket that you would cut from a sheet of gasket.
This will help but also you will find great info on other posts.
https://www.sl113.org/wiki/Electrical/Horns
250sl - later - manual
280sl - 1971 - Auto - LSD
mauro12
Re: Horn rattle
« Reply #3 on: June 09, 2019, 00:37:42 »
Yes it rattles when I honk them. Probably some went under the car and they make a strange sound not normal. Btw they are not original Bosch and I would like to replace them.
Mauro Pisani
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Horn rattle
« Reply #4 on: June 09, 2019, 01:33:12 »
Post a picture of both horns so we can see what you have.  From there we can give you advice to your options.  Prepare your wallet😁
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
mauro12
Re: Horn rattle
« Reply #5 on: June 09, 2019, 11:20:58 »
I meant to say that some water went under the car and for this reason they make a strange sound. Usually when replacing the horns you work only under the car right? You don’t have to disconnect wires from the column or steering wheel right?
Mauro Pisani
Re: Horn rattle
« Reply #6 on: June 09, 2019, 11:26:53 »
You have connectors on the horns themselves.
mauro12
Re: Horn rattle
« Reply #7 on: June 09, 2019, 11:43:20 »
So is quite easy to install for a mechanic .
Mauro Pisani
Re: Horn rattle
« Reply #8 on: June 09, 2019, 11:52:33 »
I would have thought even not for a mechanic it is easy, at least it was for me... detach and refresh the brackets as well (those made of multiple metaln plates).
Unless some screw gets stuck, but that is another, general story.
