Author Topic: Seat belt magnetic clip.  (Read 2184 times)
su8pack1
  • USA, PA, Barto
« on: June 08, 2019, 16:25:55 »
I've had my 280SL 37 years now and have never seen another clip like this.[img/Users/drkiii2017imac/Desktop/1969 280SL 501.JPG]http://[/img][img/Users/drkiii2017imac/Desktop/1969 280SL 502.JPG][/img]
1984 300CD
1987 190E 2.6
1988 190D 2.5
Re: Seat belt magnetic clip.
« Reply #1 on: June 08, 2019, 16:49:58 »
I find it quite cool, actually... The seat belt buckles are always a bit of a mess, even with hangers.
« Reply #2 on: June 08, 2019, 18:25:57 »
Actually it gives me an idea to place a piece of magnet somewhere in that place under the carpet...
There are lots of brackets on parts list for safety belts, but without pictures it is difficult to say if there is one you are showing there. There was a special version of seat belts anchoring for Japan as well.
« Last Edit: June 08, 2019, 18:35:36 by Pawel Szczesniak »
« Reply #3 on: June 08, 2019, 22:36:22 »
Almost certainly custom.  Painted wood would be far more expensive than a plastic casting if you were making a bunch of them.
wjsvb ✝︎
  • USA, VA, Virginia Beach
« Reply #4 on: June 09, 2019, 03:22:35 »
Try Ssnakeoyl (sp?) in TX.  They are knowledgeable on Kangols and may be able to help.  I like the idea!
jon
67 250SL early
12 Jeep GC (gone but not missed)
69 300SEL 6.3 Euro project (gone but not forgotten)
81 280SL Euro 4spd
scoot
  • USA, CA, Altadena
« Reply #5 on: June 09, 2019, 15:09:58 »
That is extremely clever.  I've seen a lot of Kangols and I've never see a magnet setup like that.  I think it's someone's DIY solution and a really good one at that.
Scott Allen
'67 250 SL (early)
Altadena, California
« Reply #6 on: June 10, 2019, 01:52:41 »
Ingenious!
« Reply #7 on: June 15, 2019, 20:55:27 »
I have had a go at this today. some trouble...
I did not want to drill in the chassis memebrs. I thought I could put a magnet under carpet. However - in terms of location it does not work so well with Euro door panels as they have the pockets going close to seat when you close the door. If you want to place it closer to pillar A, to be able to reach it with closed door, th ebelt is too short when adjusted (and I am not slimmest person in the world). Also: if the magnet is, say 5mm thick (what I had at hand) you see it, carpet is not lying nice and even. When a magnet would be thin, say 1mm, passenger may not use it correctly, as it will be invisible...
Magnet on the carpet - issues with holding it on to the carpet. It goes with the buckle. Tried carpet screws, tried velcro, does not work. You could screw it to the carpet with washers underneath, but it is giving it too much depth.
What I ended up with is attaching a magnet to the buckle. Then when you put down the buckle on the door sill, it stays there in order. You basically do not notice the magnet is there. The only point was that I had a pair of neodyme magnets 40mmx10mmx5mm. 5mm is a bit too high to blend in in the buckle. I will order 40mmx10mmx1 or 2mm - that should be fine. To make sure it stays in place on the buckle I used a thin double sided adhesive tape.
When I replace the magnets with 1 or 2mm thick ones, I will check if it works in practice, I will post pictures.
Maybe there are other ideas -please provide.
su8pack1
  • USA, PA, Barto
« Reply #8 on: June 16, 2019, 17:10:12 »
Just a few more pictures to show how the clip was installed.
1984 300CD
1987 190E 2.6
1988 190D 2.5
« Reply #9 on: June 23, 2019, 18:31:52 »
This is where I ended up.
Magnet 40x10x1 was too weak. I stayed with 40x10x5. I could probably order one without holes or glue in screw heads to make it look nice.
But the whole arrangement works.
