Hello everybody,
I was searching under this topic and came across your debate.
I have a copy of the BBB which says slightly different (please see the picture and its orange dot).
For engines with:
US Exhaust Emission Control,
Model Year 1970/71,
Distributor 0 231 116 062,
it should read:
@ 800 rpm (idle) - 8º ATDC
@ 1500 rpm - 0-5º BTDC
@ 3000 rpm - 25º-30º BTDC
Does it make sense?
Also, according to what I read, 8º ATDC is a retard ignition and all BTDC are advances.
Yet, the Emission control system says that advance is only turned on at 2400 rpm; that leaves the 0-5º @ 1500 rpm in a limbo, once retard should only be set back at 2200rpm.
Any comments?
Many thanks
