Author Topic: Automatic Gearbox check valve breaking  (Read 4561 times)
db180
« on: June 20, 2019, 15:57:35 »
I'm looking for a Automatic Gearbox check valve - A11227701389, current one has been discovered as damaged on my 250sl and needs replacing.
Any help locating one would be greatly appreciated.
DB180
Re: Automatic Gearbox check valve breaking
« Reply #1 on: June 20, 2019, 20:40:44 »
So you have a picture?
« Reply #2 on: June 21, 2019, 14:07:08 »
Too many digits in that part number.
db180
« Reply #3 on: June 21, 2019, 20:58:32 »
Hi Joe - unfortunately don't have a picture - gearbox is at the shop. Colin thanks for pointing out the invalid part number it's A1122701389
It's item 198 in the diagram.
Thanks.
« Reply #4 on: June 23, 2019, 21:46:07 »
Drop the “A” and do a google search.  It is shown as available from Mercedes in the US for about 90USD.
db180
« Reply #5 on: June 24, 2019, 08:39:58 »
It's not available from Germany - I did try ringing Pelican and they checked and said it was also NLA in USA
rusty747
« Reply #6 on: June 24, 2019, 21:45:11 »
ECS Tuning showing them as available at $92.
Good luck
« Reply #7 on: June 25, 2019, 08:48:48 »
I have a spare gearbox in my attic.  I will see if it is the right one.  I know there is a split between early and late I am not sure where.  I should be able to  tell from the drawing.
« Reply #8 on: June 25, 2019, 11:53:35 »
I have a good used one. Send me a message if interested.
« Reply #9 on: June 25, 2019, 23:18:54 »
Colin is much closer.
