I've read that you should measure 1 liter per 15 seconds after the fuel damper. Mine was barely dribbling out of the hose, so we removed the fuel pump and cleaned the screen, which was clogged with small particles of rust and dirt. However, the fuel is still flowing back from the damper at a very low rate. There is now at least 1 liter / 15 sec of flow into the filter, which is rather new. Is there any other filter or screen in the system?
