Author Topic: removing wedge bolt rear axle  (Read 2200 times)
merrill
« on: June 22, 2019, 18:05:57 »
hello
i pulled both axles today and prepared to somehow remove the wedge bolt.
I situated the the axle so the pinion is pointing up and i can see the wedge bolt.  right hand side tube is parallel to the drivers side.
i cannot get a straight  approach to tap out the wedge bolt,   any tips on how to get that sucker out?
can i swing the axle "up" more to gain access?
« Last Edit: June 22, 2019, 19:25:15 by merrill »
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
mbzse
Re: removing wedge bolt rear axle
« Reply #1 on: June 22, 2019, 19:25:29 »
Quote from: merrill
.../... the wedge bolt, any tips on how to get that sucker out?
Yes, certainly, you should. Remove the transverse spring to begin with, of course.
For tips on wedge bolt (tapered pin) removal, see these postings:
https://www.sl113.org/forums/index.php?topic=27652.msg198978#msg198978
/Hans S
merrill
« Reply #2 on: June 22, 2019, 19:29:08 »
Hans
hi,
thanks for the link,  i saw a note from Joe that mentions swinging the axle up
i will give that a try
any yes the spring is off  8)
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #3 on: June 22, 2019, 22:04:15 »
Be careful to not put a load on the axle in the up position as you can break the axle housing very easily.  If I were you I would just cut the boot away so you can keep an eye on it.The casting is very thin where the axle goes though the bellows area.  I recommend tapping it out rather than trying to press it out.  I used a hammer and brass drift.  New pins were $125 last time I checked.
merrill
« Reply #4 on: June 22, 2019, 22:23:55 »
well it turns out if you turn the axle over and let the swing arm move past level the bolt for the wedge nut is exposed.
i may try to use an air hammer on the wedge bolt.  of  course leaving the nut on and using something as a buffer between the air hammer and nut/wedge bolt.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
« Reply #5 on: June 22, 2019, 23:23:54 »
well using a brass draft and a small hammer the wedge pin came out after a few firm solid taps.
got to de grease it over night to see if it i can use it again
not on to the axle pivot bar
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
« Reply #6 on: June 23, 2019, 17:54:19 »
well after letting the de greaser do its job overnight i was able to inspect the wedge bolt.
unfortunately the threaded portion is bent, i was able to clean up the threads with a die and get the nut to thread on nicely.
i may break down and buy a new one from SLS.  its about $70 U.S.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
