Author Topic: Found In The Trunk Of My 1967 250SL  (Read 5816 times)
NoEcm
« on: July 03, 2019, 18:15:50 »
It all started here: https://www.sl113.org/forums/index.php?topic=29220.0.
I went through the trunk today and inside the spare tire cover I found the following:
A couple of the wrenches are missing; 2 are marked "Matador Western Germany" and 1 is marked "Dowidat Made In Germany". I'm not sure which ones are original to the car.
I think a pair of slip joint pliers are also missing
The case is a red vinyl material in just OK condition
A couple of maps showing the different Mercedes Service Centers around the world
Blaupunkt owners manuals
A metal tag embossed (letters are reversed and backwards) with the car information
A "How To" for using the metal stud when changing a tire
Re: Found In The Trunk Of My 1967 250SL
« Reply #1 on: July 03, 2019, 18:53:47 »
I think you are a very, very lucky person!
mbzse
« Reply #2 on: July 03, 2019, 19:15:28 »
Quote from: NoEcm
.../...A couple of the wrenches are missing; 2 are marked "Matador Western Germany" and 1 is marked "Dowidat Made In Germany". I'm not sure which ones are original to the car.
I think a pair of slip joint pliers are also missing.../...
Nice original tool kit! As you mention, some items are not there.
A lot can be read in the Forum archive about this theme, see for instance:
https://www.sl113.org/forums/index.php?topic=25999.msg186193#msg186193
Also the Technical Manual
https://www.sl113.org/wiki/Accessories/Toolkit
/Hans S
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« Reply #3 on: July 03, 2019, 20:22:10 »
Nice score!
My docs included Blaupunkt manuals, but my Blaupunkt was some '80s cassette player, so I tossed it.
DOn't know what to do w/the manuals.
« Reply #4 on: July 03, 2019, 22:31:23 »
Nice bonus, these items are bringing good money these days. The original wooden handled screwdriver seems to be in especially good condition.
wayne R
« Reply #5 on: July 03, 2019, 22:56:38 »
Nice score!
Hi teahead, the  Blaupunkt  you tossed  if they were  model  Monterey they are worth
money,especially  for Porsche, 911 ---One of the best user friendly radios out there, regards .
teahead
  • aka "Rob"
« Reply #6 on: July 03, 2019, 23:00:30 »
Hmm...Blaupunkt Cr-2010.  Maybe I'll go dumpster dive for it again.  Didn't think anyone would want this POS:
su8pack1
  • USA, PA, Barto
« Reply #7 on: July 03, 2019, 23:33:25 »
Great find. I was lucky to get all of mine.
1984 300CD
1987 190E 2.6
1988 190D 2.5
NoEcm
« Reply #8 on: July 04, 2019, 03:30:31 »
I found this in the passenger door side pocket:
And now I know what this socket is used for:
« Reply #9 on: July 04, 2019, 11:56:26 »
You need the pliers, fuse pulling pliers and the fuse kit.   The fuse pullers and fise kit are available from Authentic Classics.  I believe you can get the pliers from them as well but the current version is not stamped with the MB star logo.
There seems to be no rhyme or reason to the wrenches as long as they all from the same manufacturer. Usually a bunch on eBay as individual wrenches.
« Reply #10 on: July 04, 2019, 14:58:15 »
Your VIN is within shouting distance of mine (1344)!
Would you look at the owner's manual, on the back page there should be a part number -113 584 XX 96, what are the XX digits in the manual you have? What is the date - this is also on the back page with the format similar to 3.67 (or reversed).
Does the power plug for the round spotlight fit in the lug on the firewall? It appears to be larger. That is not what was available at the time and appears it would be for the cigarette lighter.
NoEcm
« Reply #11 on: July 04, 2019, 15:15:43 »
Manual:
The back cover (outside) of the owner's manual has 113 584 09 96 and no date
The last page has "KTDF IV. 67. 6. Hg. Printed in Germany"
Spotlight:
The plug as show in the picture fits into the socket of the firewall.
The adapter (or cap) as shown in the picture when fitted onto the small spotlight plug then fits the cigarette lighter receptacle.
mbzse
« Reply #12 on: July 04, 2019, 16:30:22 »
If one went to one´s dealer in the 1960´s (and later) with intent to buy a plug in lamp for the engine bay of the Pagoda, this is what they would supply you with. A so called "Kaco" trouble light with a very long wire and the light unit has a clamp.
Note the bakelite plug; this fits into the socket fitting on the firewall
« Last Edit: July 04, 2019, 16:43:43 by mbzse »
/Hans S
« Reply #13 on: July 05, 2019, 01:57:46 »
Thanks for the information on the date 6.67 and part number.
As Hans has written the in period trouble light is the Kaco. There was a spotlight available also, intended to be mounted on the windshield. I had never seen the compact circular one you had posted.
« Reply #14 on: July 05, 2019, 02:31:04 »
I have a 1967 230S in right now and the owner uses it for vintage rally events. He has some neat stuff inside the car but he also has one of those vacuum operated spot lights that stick to the windshield. I saw one on a 190SL once and knew at once what it was but I'm also sure it's a rare piece.
mbzse
« Reply #15 on: July 05, 2019, 07:58:39 »
Quote from: Benz Dr.
.../...one of those vacuum operated spot lights that stick to the windshield.../...
There were two manufacturers for this, Hella and Helphos.    A couple of pictures attached
/Hans S
« Reply #16 on: July 05, 2019, 15:22:21 »
This one is black with no chromed ring.
mbzse
« Reply #17 on: July 05, 2019, 15:26:20 »
There was a dark grey version, yes. Detail differences over time as well
« Last Edit: July 05, 2019, 15:30:35 by mbzse »
/Hans S
« Reply #18 on: July 05, 2019, 16:21:58 »
This one is a Helphos. Black or dark gray and does have a chrome ring around the light.
