Author Topic: How to tell a 5 speed  (Read 2909 times)
rockingchairmotors
  • USA, PA, Coplay
  • 1-610-972-9694
« on: July 12, 2019, 20:46:01 »
I have been presented to me a supposed ZF 5 speed.
Can anyone tell me what to look for to determine if it is in fact a true ZF 5 speed.
The number on the case is 111 261 05 01.  My info says that it is a 4 speed.  Am I wrong?  Can someone post a picture, if possible, of a 5 speed.
Thanks in advance.
mbzse
Re: How to tell a 5 speed
« Reply #1 on: July 12, 2019, 21:29:10 »
Quote from: rockingchairmotors
.../...Can anyone tell me what to look for to determine if it is in fact a true ZF 5 speed.../...
There is a manufacturers plate with the serial No of the box on its left side (see pic attached)
"ZF" is cast into the housing and the alloy rear end piece also.
« Last Edit: July 12, 2019, 21:33:54 by mbzse »
/Hans S
« Reply #2 on: July 12, 2019, 22:07:38 »
Sure looks like the one I have.  One a 4 speed, reverse is to the left beside first gear. On a 5 speed, reverse is over to the right and below fifth gear. Pretty hard to confuse them.
« Reply #3 on: July 12, 2019, 23:08:12 »
Naa.. Rockingchair....,
Quote
You are wrong.
That's an ordinary MB 4-speed gear box in the car you look at, no true 5-speed.
(5-speed probably only because there is also a reverse ...)
The real ZF 5-speed as pictured does not carry any MB numbers, only ZF numbers.
It's larger and much longer than the ordinary 4-speed.
« Reply #4 on: July 13, 2019, 09:42:33 »
Doesn’t it go faster than a 4 speed?
ejboyd5
  • Southold, NY
« Reply #5 on: July 13, 2019, 11:45:57 »
Please remove tongue from cheek before posting.
« Reply #6 on: July 13, 2019, 18:33:20 »
I can always tell if it's a 5 speed transmission. I just can't tell it much.
