I've read all I could find here on this topic and would like confirmation some of the data if the techies (or not so technical) can help out. I have to admit that I'm a bit confused
Here's what I think is correct for my car/distributor: 1967 230SL 2.3L L6 Distributor: 231 116 051
vacuum retardpoint gap: .012-.016"
timing: 8 degrees BTDC @ idle with vacuum line disconnected (this doesn't seem right with a vacuum retard system)
timing: 30 degrees @ 3000rpm
idle speed in neutral: 700-800
dwell is assumed to be 38 degrees based on other similar L6 Mercedes from the same years?
I did measure dwell and it's @ about 45 degrees so it looks like the points aren't gap'ed correctly.
I would also like a pointer to the correct shop procedure for setting point gap and timing - I couldn't find that specific info either. I can figure this out but it would be nice to actually read the MB shop procedure if it's available.
