Author Topic: Confused about the "Linkage Tour"...  (Read 7256 times)
teahead
  • USA, WA, Des Moines
  • aka "Rob"
Re: Confused about the "Linkage Tour"...
« Reply #25 on: July 30, 2019, 04:48:27 »
OK, idle in N is about 750
Idle in 4...~600-650.
Just a hint of hesitation now.
Maybe I need to hook up my constant speed solenoid?
« Reply #26 on: July 30, 2019, 15:57:26 »
Hesitation can be caused by low fuel pressure, is your main filter clean?
teahead
  • aka "Rob"
« Reply #27 on: July 30, 2019, 16:03:53 »
Ya, brand new.
brand new plugs, brand new spark plug wires, cap/rotor/points changed.
I'm still confused also about the CSS (constant speed solenoid).  I have no wires going to it; just the wires that are on it.  So I can assume it's not doing anything?
With the car in gear, and barely running at 600 RPM, if I just give it a hair of gas pedal, she runs really good at 700.   Thinking of that CSS was hooked up, it'd give it just enough for the car to idle good at 700 RPM in gear.
Wonder why the factory installed the CSS and not hooked it up?  It's an automatic car for goodness sake.  Was the thinking that auto cars then, the dashpot was good enough and if a dealer wanted to add AC, they'd just hook up the CSS then?
« Reply #28 on: July 30, 2019, 22:37:12 »
Adjust the dashpot so you get more rpms in gear.  With latter USA cars, when a dashpot was used, the CSS was wired to work only if the car was equipped with AC. If the car came fron the factory with no AC, then the CSS was installed but never wired.
teahead
  • aka "Rob"
« Reply #29 on: July 30, 2019, 22:39:06 »
Ya, if I crank up the dashpot even more than I did, car runs rough.  This was after I turned the IP thumbscrew to the right I think, 4 clicks, to get it rich.
« Reply #30 on: July 31, 2019, 02:21:41 »
Try another click or two richer.
