Sorry, I'm still confused (dense for sure).
The "Linkage Tour" states:
Disconnect the linkage rod going from the cross over rod to the venturi. If you have a USA version with the vacuum dash pot, you will need to move it out of the way so it does not interfere with the adjustment. The small slotted venturi set screw must be backed off enough to allow the venturi valve to close all the way and then adjusted in just enough to keep the venturi valve from binding in the intake.
USA 280SLs had an "Vacuum throttle control" on the intake venturi linkage. A special linkage with a "slip joint" was also used between the venturi and the cross-over rod on the engine. Adjust the slip joint linkage so it is fully compressed with the engine running and warm at idle in neutral. Adjust the vacuum control/linkage to
zero clearance. Now with the transmission in gear, the throttle lever will open 1.0 mm to 1.5 mm.
After I do (1) above, do I put BACK the dash pot before I adjust the slip joint to be fully compressed (step 2)?
Also, the dashpot...when is it in gear, does the adjusting screw push out or pull in? I guess I can remove it, but keep the vacuum connected and see how it operates while running/putting it in/out gear.
