Author Topic: Accelerator linkage rod urgently required for 230sl 1964 Uk car  (Read 2061 times)
Raffles84
Hi , can anyone help me as to where I can find an accelerator linkage rod as during the nit and Bolt restoration Mir has sadly been lost.based in London so any assistance would be appreciated. Many thanks
Re: Accelerator linkage rod urgently required for 230sl 1964 Uk car
« Reply #1 on: July 15, 2019, 03:55:56 »
Which one do you need?
Raffles84
« Reply #2 on: July 15, 2019, 18:32:11 »
Hi , I need the one with the rubber bush set in the circle !
« Reply #3 on: July 17, 2019, 20:25:49 »
I believe it is still available from Mercedes.  I looked one up for a 280 a couple weeks ago.  possibly #1133000015 which shows still available.  Check with your dealer.  If it isn't available it isn't a tough one to make.  I just made one for a 280 a friend is working on a couple weeks back.
« Last Edit: July 17, 2019, 20:45:53 by Shvegel »
« Reply #4 on: July 18, 2019, 08:10:49 »
I have just looked it up in the EPC:
A 113 300 00 15 As of ident. no.: 042 012467 ALSO INSTALLED ON 012323-012352, 012354-012366, 012369-012376, 012378-012387, 012389-012412, 012414-012422, 012424, 012444, 012446-012465
A 111 300 12 15 Up to as above - 1.
But it is not available, the system says.
However: they are not LHD or RHD specific, it is the same part.
Raffles84
« Reply #5 on: July 18, 2019, 09:01:45 »
Any ideas ??? As I need this part now !! Thanks so far to all for the input
« Reply #6 on: July 19, 2019, 06:16:26 »
This linkage configuration was quite common on many other Mercedes of the era. Only the length was different in some cases, but each end is often the same. If you find one that is too short, you cut in in two. Use some correct size steel tubing, slip the two halves into the tubing, adjust it to correct length, then braze it together.
« Reply #7 on: July 19, 2019, 12:21:46 »
Or...
if you find a too long one you can shorten it.
This is how I once did it with my 114 part.
Good luck
