Author Topic: Removal of auto trans cover plate?  (Read 3178 times)
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« on: July 18, 2019, 00:17:09 »
Googled...nada.
Anyone know how to remove it?  Want to replace the light bulb in it.
Delvis
  • Canada, British Columbia, Delta
Re: Removal of auto trans cover plate?
« Reply #1 on: July 18, 2019, 00:51:53 »
Hello. You will need to slowly peel back the tunnel carpet. One removed far enough you will find some hardware to remove. Four bolts. Once removed you can lift up the chrome assembly to expose the light holder. If needed you can also remove gear shift knob by firmly pulling straight up. I used grips to remove but first wrapped the knob with a thick towel so I didn’t harm anything. Hope this helps
Devlin
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
Delvis
« Reply #2 on: July 18, 2019, 00:54:33 »
Ps. I’ll trade you the tunnel carpet. Original stuff would look awesome in my 280SL.
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
« Reply #3 on: July 18, 2019, 01:30:46 »
Don’t get too bright a torpedo bulb- it’ll be brighter than your dash bulbs.
NoEcm
« Reply #4 on: July 18, 2019, 18:31:26 »
I just rebuilt/repaired my automatic shifter mechanism and linkage using this thread:
https://www.sl113.org/wiki/TransmissionClutch/Shifter
JM Girardot
  • USA, GA, Blairsville
« Reply #5 on: July 31, 2020, 18:52:30 »
Good afternoon, I am a new member (September 2019) and got a 1970 280 Sl pagoda in dark green with tan leather interior.  I have done some work on it and still have a long way to go.  The other day, as I was on reverse, I couldn't get out of rear shifting because the plastic bushing from the shift gate to the rod going to the transmission broke and disappeared in the tunnel.  Since I had the shifter out I decided that I would replace the plastic parts and reassemble the shifter.  I am waiting for the kit and I was looking at your description and you mentioned that the inside spring needs to be installed properly for the shifter to work correctly.  I have tried to look at the photos that you posted but due to the grease I cannot see how the spring is positioned inside the shift gate.  I also don't know if the spring was in correct position in the car that I got a year ago.  Thanks for your help.
2004 S500
1972 280 SEL Blue/silver top. SOLD
1972 280 SEL Light green. SOLD
JM Girardot
« Reply #6 on: August 01, 2020, 14:01:14 »
Problem solved, put it together outside the box and it fits and works properly.
2004 S500
