Author Topic: Complete and Correct Tool Kits for sale  (Read 15905 times)
mmizesko
  • USA, OH, New Albany
« on: July 21, 2019, 18:24:24 »
I think I have about 9 correct 113 Tool Kits for sale.  With centering guides, Fuse Kits, Fuse pullers, Star on the Water Pump Pliers.  Rare as hens teeth.  $975 each plus postage.  PM me if interested.  Tools part of kits only.
Mike Mizesko
1970 280SL 291H Dark Olive
wayne R
Re: Complete and Correct Tool Kits for sale
« Reply #1 on: July 22, 2019, 08:06:22 »
Mike ,would you mind advising  me ,with my tool kit,
it has 5  spanners  4 are Dowidat and 1 is a Walter, see in photo  13x17
should  this also be a Dowidat , as i have never seen a  13x17 Dowidat
for sale -----is there such a size.
i have---8x10
            11x13
            14x17
            17x19
and the Walter is  13x17--thankyou.
« Last Edit: July 22, 2019, 09:11:36 by wayne R »
mmizesko
« Reply #2 on: July 23, 2019, 18:42:19 »
Dowidat never made one with the Mercedes Branding that I've ever seen.  Mercedes added 13mm bolts and nuts sometime in the late 1960's, perhaps at the 250SL or 280SL change.  I am not sure if they discontinued the 14mm.  I'd have to ask Joe or someone more experienced than I.  Earlier kits did not include a 13mm wrench.
So it depends on your model year.  Every kit I provide has a 5th wrench, the Walter 17x13.
If you have it, it can't hurt.
Let me know if you have any questions.  I browsed the model year changes chronologically, and couldn't find the crossover date.
Mike
mbpaul
  • USA, NM, Albuquerque, NM
« Reply #3 on: July 23, 2019, 20:08:00 »
The wrenches in my 1966 230SL have Mercedes Benz on one side and Dowidat on the other.  One is a 10X13 wrench.  I think these are the ones that came with this car but since I have had more than 10 Mercedes, I could have mixed them up at some time.
I also have a Mercedes Benz/Heyco 13X17 wrench in my tool box (not in the 230SL).  Not sure where or when it came from.
wayne R
« Reply #4 on: July 23, 2019, 22:19:27 »
Thank you Mike for that information.
mmizesko
« Reply #5 on: July 24, 2019, 20:41:11 »
MB Paul:
Wayne's set is Standard issue in all the kits I'm aware of.
8x10
11x13
14x17
17x19
Who the heck knows where the 10x13 is from...
The more I learn, the more confused I look.
Mike
wayne R
« Reply #6 on: July 25, 2019, 06:06:10 »
Just to confirm , photos  to show.
If any body has a Dowidat din895----13x17 i will gladly
swamp it for my  Walter din895------ 13x17---its my odd ball
one in my kit, and ill pay shipping.  regards.
« Reply #7 on: July 25, 2019, 22:34:15 »
I will check my inventory when I get back to the house.
Update, I have only one 17X13 and it is branded Walter.
« Last Edit: July 26, 2019, 15:18:49 by Jonny B »
mmizesko
« Reply #8 on: July 26, 2019, 21:30:49 »
I've got 100 of these mercedes marked wrenches, and the only 17x13's are the Walters.  Good Luck in finding one.  If I ever see one, I'll let you know.
Mike
wayne R
« Reply #9 on: July 27, 2019, 06:44:24 »
Mike
Thank you Mike,------.
mbzse
« Reply #10 on: July 27, 2019, 09:22:09 »
Quote from: wayne R
.../...my  Walter din895------ 13x17---its my odd ball.../...
Sudden interest for these 13x17 wrenches?  ???
They were never part of the tool rolls delivered with our Pagoda cars from factory.
/Hans S
mbzse
« Reply #11 on: July 27, 2019, 09:31:24 »
Quote from: mmizesko
.../...Mercedes added 13mm bolts and nuts sometime in the late 1960's.../...I am not sure if they discontinued the 14mm.../...
As mentioned before, the M8 hardware was changed in the DIN industrial norm in 1965. Before that, M8 had a 14mm hex (nuts and bolt heads). After, this was 13mm.
So, the entire industry, including automotive of course, started using 13mm key width. More nimble, and some less weight in a machine too.
14mm wrench ends (14x17) were indeed retained and needed in the M-B tool kit, because some fittings on the car have this size even after 1965.
« Last Edit: July 27, 2019, 20:34:29 by mbzse »
/Hans S
« Reply #12 on: July 27, 2019, 19:33:27 »
Heyco made 17x13 wrenches for Mercedes as MB Paul wrote. The longer black 350 pre-Pagoda and later shorter DIN 895 models.
« Last Edit: July 27, 2019, 19:55:02 by 66andBlue »
wayne R
« Reply #13 on: July 28, 2019, 00:38:06 »
Alfred you are a Champion, many thanks for that,
send me another PM, as i messed up the last one----regards Wayne.
« Reply #14 on: July 28, 2019, 00:43:03 »
Sent you another one with the link.
Let me know if you have problems.
mmizesko
« Reply #15 on: July 28, 2019, 15:24:47 »
Hans,
I have seen supposed "original" 280SL tool kits, and they did indeed have the Walter wrench in them.  I don't think most owners would go out and try to find one if the kit didn't have one.
Thanks for the input on the 14mm vs 13mm timing.
Mike
wayne R
« Reply #16 on: July 28, 2019, 22:34:49 »
Many Thanks  Jonny B, Mike, and others,especially Alfred
for finding  a Dowidat 13x17 wrench for me, from Germany.
wayne R
« Reply #17 on: July 29, 2019, 02:45:19 »
Forgot to mention ---Mike and Hans----You are  correct re the wrench,
this one does not have the word  Mercedes on it,  has,
13x17  Dowidat------Germany, on one side,and the other side is
13x17  Din 895------standard material with a very smal 1/4 inch circle at end.
But im happy to obtain it,  can send photo  later if wanted, regards .
Nericlaster
« Reply #18 on: October 08, 2021, 15:21:47 »
Do you still have the tool kits?
My contact is elaster@edificeinc.com
Thank you’
Eric laster
hmplatts@gmail.com
  • USA, CO, Denver
« Reply #19 on: March 11, 2022, 14:00:18 »
Hello, I need a complete and correct tool kit for my 69 280SL, will begin touring it soon thanks!
Henry
MikeSimon
  • USA, OH, North Royalton
« Reply #20 on: March 11, 2022, 17:57:33 »
I can always add and muddle the picture a little:
I have several 17x14 Wrenches. Matador, Heyco and Dowidat. They ALL say Mercedes Benz on them. Including the Dowidat
I also have a 17x13 Walter.
And a 14x11 Dowidat. Again, all Mercedes Benz
« Last Edit: March 11, 2022, 18:02:02 by MikeSimon »
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
MikeSimon
« Reply #21 on: March 11, 2022, 17:59:20 »
Walter 17x13
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
MikeSimon
« Reply #22 on: March 11, 2022, 18:01:23 »
Dowidat 14x11
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
MikeSimon
« Reply #23 on: March 12, 2022, 16:48:23 »
I searched the Tech Manual and all my records for a list of the correct on-board tools in the kit for a 1970/71 280SL and could not find anything.
Does anybody dare to post the complete list?
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
MikeSimon
« Reply #24 on: March 13, 2022, 18:18:20 »
Never mind fellas! The memory is the first to go. ::) Looking through my records I found a complete thread about this from 2 years ago which I printed out!
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
