Author Topic: Brake Booster  (Read 2497 times)
Harry
  • USA, TN, Knoxville
Brake Booster
« on: July 26, 2019, 01:05:05 »
In disassembling my brake booster (1966 230SL), I found some old brake fluid in the chamber on the master cylinder side.  It was very brown, as though it had been there a while.  I don,t see any indication of leakage on the master cylinder so my guess is that it was leaking at some point and was repaired.  It also wasn’t losing fluid before I took the cylinder off of the booster.  Just want to be sure that there shouldn’t be fluid in this area?  Correct?
Probably should rebuild anyway.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Brake Booster
« Reply #1 on: July 26, 2019, 04:49:31 »
It should be dry inside. Not a bad idea to rebuild.
Harry
Re: Brake Booster
« Reply #2 on: July 26, 2019, 15:55:17 »
Thanks very much.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
