Author Topic: steering wheel off center..  (Read 2651 times)
danellen4
« on: July 29, 2019, 05:55:08 »
New to the group here and im curious if anyone can tell me what would cause the steering wheel on a 69 280sl to be off center.    when u look thru the steering wheel into the gauges the steering wheel is about 1/2 an inch to the left of center.      Thanks in advance.
« Last Edit: July 29, 2019, 06:06:58 by danellen4 »
WRe
Re: steering wheel off center..
« Reply #1 on: July 29, 2019, 06:59:58 »
It's normal that the steering wheel is a little bit slanted to the left to allow easier access to the car.
...WRe
« Reply #2 on: July 29, 2019, 12:08:20 »
Additionally, I don't believe there is any adjustment possible to the position of the steering wheel and column, it all seems solidly bolted in one position.
What WRE is referring to is that the steering wheel is closer to the dashboard on the left side than on the right side, indeed to ease ingress and egress.
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: July 29, 2019, 13:07:21 »
It also has to do with the position of the steering column in the car. The lower end of the column connects to the linkage for the steering gear. In order to achieve even turns for right and left, that connection point needs to be in a certain spot. Thus usually on most cars, the steering column is on a slight angle from the driver position towards the center of the car. This will minimize the amount of U-joints needed to accommodate angles.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
su8pack1
  • USA, PA, Barto
« Reply #4 on: July 29, 2019, 22:22:24 »
Just use a steering wheel puller. Pull it off and put it back on straight. Might have happened during an alignment.
1984 300CD
1987 190E 2.6
1988 190D 2.5
danellen4
« Reply #5 on: July 30, 2019, 04:31:17 »
thanks for the info and feedback,   ill sleep a little better tonight
« Last Edit: July 30, 2019, 11:17:17 by danellen4 »
MikeSimon
« Reply #6 on: July 30, 2019, 23:11:33 »
I don't think the PO was talking about an "angle off center' misalignment."
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Pinder
  • USA, NJ, Edison
« Reply #7 on: August 15, 2019, 21:34:10 »
It can be off center if there has been some kind of crash the hub came from. from another car. the hub can deform pretty easily. I purchased a hub for the steering wheel online and it looked normal unilt installed on the car then it made one side of the steering wheel look like it was closer to the dash. It must have been salvaged from a wrecked car.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
« Reply #8 on: August 16, 2019, 03:32:40 »
It can be off center because it's off center. Not hard to undo the nut holding the wheel on and turn the wheel a little bit left or right.
« Reply #9 on: August 16, 2019, 05:18:03 »
The left side of the steering wheel IS supposed to be closer to the dash (quite a bit), see previous posts.
Paul & Dolly
  • i Car
« Reply #10 on: August 16, 2019, 08:33:09 »
Danellen
There is a lot of good info in the Technical Manual here.
Do a search for Steering Wheel in the technical manual on site here.
You will see the different types of wheel and removal and fitting processes.
There is also an alignment mark on the shaft,so the indicators function correctly,this should be at either 6 or 12 o clock position,dependant on a RHD or LHD vehicle or vice versa.
Good luck
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
