Author Topic: 2-pole terminal for Bosch Supertone horn  (Read 5382 times)
« on: August 01, 2019, 03:13:29 »
Looking for a used or new 2-pole spade terminal for a later Bosch horn.
Re: 2-pole terminal for Bosch Supertone horn
« Reply #1 on: August 09, 2019, 02:21:37 »
Those are single spades with rubber boots.
WRe
« Reply #2 on: August 09, 2019, 06:54:43 »
Hi Alfred,
I know it as 2 single fully insulated receptacles (voll isolierte Flachstecker) too, in black with round end to fit in the horn.
... Wolfgang
« Reply #3 on: August 09, 2019, 18:05:03 »
Shvegel, it is not a rubber boot but hard plastic.
Wolfgang, actually it is one piece with two separate feed-through poles.
Fortunately I found one in white and it is on order.
WRe
« Reply #4 on: August 10, 2019, 08:07:56 »
Hi Alfred,
ok, never seen. Was this horn ever used in our cars?
...Wolfgang
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« Reply #5 on: August 10, 2019, 14:35:01 »
Where'd you get it?
« Reply #6 on: August 10, 2019, 17:44:52 »
Hi Alfred,
...Wolfgang
Hi Wolfgang, no, never on a W113 car. I believe these horns were made around 1990-2000 and few came with the 290Hz/345Hz combination, most were 325Hz/400Hz.
I found this (290Hz/345Hz) horn pair at a swap meet and thought I could just exchange the connector for the ring-type connector. Well, as you can see that does not work.
They show up occasionally on eBay.
« Reply #7 on: August 12, 2019, 03:00:35 »
Alfred,
I see now.  I thought you were looking for the terminals that plug into your horn not to replace the cracked one you had.
m300cab
  • USA, Pennington New Jersey
« Reply #8 on: August 14, 2019, 13:37:41 »
i have an old 113 horn if your interested
Michael Parlato
teahead
  • aka "Rob"
« Reply #9 on: August 14, 2019, 14:22:37 »
Alfred,
Me too.
