Author Topic: Minor reconditioning of the wood center console  (Read 3086 times)
russelljones48
  • USA, NC, Mooresville
« on: August 04, 2019, 21:31:05 »
Mine was "loose" but the hold down screws were tight so I took it out of the car to see what was needed and clean it up a bit.  My question is this - the bottom was what was loose and it was held to the box with staples.  Is that stock or was this an ill-conceived fix and I should glue it?  I gently re-seated the staples and cleaned, waxed, and buffed it and it now seems solid and looks better but I will take it out, remove the staples and glue it if that's they way it was made originally.
Mike K
Re: Minor reconditioning of the wood center console
« Reply #1 on: August 08, 2019, 20:29:16 »
I went through the same exercise a few years ago. Mine was also held to the box with staples, I believe that was how it was done from the factory.
I removed the old staples, took my staple  gun and reinstalled new ones. All OK.
Mike
TJMart
  • USA, NC, Matthews
« Reply #2 on: August 09, 2019, 19:01:18 »
Russell,
I had mine refurbished with all rest of the wood by a well known restorer of wood and it had the staples when finished.
Tony
1970 280SL, 4 Speed
bogeyman
  • USA, NE, Omaha
« Reply #3 on: August 09, 2019, 19:26:05 »
I have 3 - two original with staples and a 3rd that was restored by Drew Tibkin. He used small brads to attach but there is evidence of the original staples there.
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
russelljones48
« Reply #4 on: August 11, 2019, 13:09:44 »
Thanks guys.  this little car is certainly an adventure.  I feel much better knowing that there's a high probability that staples were used by MB and will leave it that way.   8)
