I like to put the head on by itself with the camshaft only(spark plugs out). Snug the head bolts and connect the timing chain and install the tensioner. Double check your valve timing marks and distributor orientation. At this point you can torque the head to specs. Next, temporarily snug the exhaust manifolds to the head by themselves. You can easily bolt and tighten the front pipes to the manifolds now. Next loosen the exhaust manifolds at the head so you can install the intake manifold. Next do the final installation and tightening of both intake and exhaust manifolds at the head. I like to install each rocker arm and adjust the valves one at a time, while rotating the engine, till all are installed and adjusted. Before installing the plugs, crank the engine with full throttle until fuel emerges from each loose injector line (at the head). Tighten all the injector lines install the plugs and start the engine. You may need to coax coolant into the system before it starts to circulate on its own. The top tank of the radiator will become hot when the thermostat finally opens and coolant begins to circulate. Do not run out for a test drive before you properly "burp" the cooling system or you may overheat the engine. Factory Workshop Manual BBB suggests re-torqueing the head after first warm-up and then again after 500 miles. Adjusting the valve again at these intervals, after engine cools down, will get your engine nice and quite.
