Originally posted by TR
Mike -- I've never seen a fire extingusher mounted in the cockpit of a 1st rate W113. But I must say the idea of having the extingusher as close at hand as possible is good. Do you leave your fire extingusher behind the driver's seat when showing your 280SL?
Tom,
In Concours generally you aren't dinged for safety related items; thus the fire extinguisher wouldn't count against you. However I do remove non-essential items just for a cleaner look. Then again, perhaps my 113 isn't first rate with that fire extinguisher in plain sight...but I feel better with it there.
Attached is a photo of my interior with the fire extinguisher behind the seat. It is a cheap model from Costco. Not chrome or Halon, but the dry chemical and the paint looks remarkably close to 568 Signal Red!
How'd that happen? These fire extinguishers generally have a plastic bracket/clamp that you
can screw into something and they also have a coarse velcro like tab which allows them to remain in place when pushed onto carpet. Mine has not moved at all--even under hard cornering--unless I chose to move it. But it is quite easy to remove for cleaning, concours, or emergency--grab it and go. There are those that will tell you the woes of dry chemical, but trust me if you have a fire, the least of your concerns will be how it was put out. If the fire department comes--and they usually do unless you are in the boonies--
you can't tell them what to do and hundreds of gallons of water at 400 PSI will render the dry chemical/Halon issue pretty moot.
Which brings up my final point--keep your insurance up to date and make sure it is good for a fire! Classic car insurance is generally better to have then "regular" as there are agreed upon values and you don't have the issue of them dictating how or where your car can be repaired.
Download Attachment: FireExting.jpg76.56 KB
