Author Topic: Brake Pedal  (Read 1228 times)
rbouch8828
  • USA, MA, Framingham
  • 280SL Mfg date AUG 1969
Brake Pedal
« on: August 26, 2019, 17:56:55 »
I am trying to loosen the brake pedal so I can get behind it to treat some surface rust. The diagram shows that there is a pin holding it to the throttle lever. Does anyone know if you just pull out this pin with a pair of pliers? Or do you have to remove it in some other way to get the pedal to flop down?
RB
