Author Topic: auto transmission noise  (Read 2876 times)
al11
« on: February 18, 2005, 15:15:42 »
My automatic 280 sl has made off and on, for the last week , a funny noise from the shifter area similar to something being dragged under the car . Does anyone know what the reason is?
Re: auto transmission noise
« Reply #1 on: February 18, 2005, 15:44:50 »
Perhaps you're ragging something under the car!   :D   Did you check?
 - Does this happen in any forward gear?  (Try manually selecting them on your next drive.)
 - Does this happen in reverse?
 - Does this happen at any particular speed range, regardless of gear?
 - Does this happen when engine is under load (accelerating)?
 - Does this happen when engine is not under load (coasting)?
« Last Edit: February 18, 2005, 15:45:14 by rwmastel »
« Reply #2 on: February 18, 2005, 16:00:03 »
Al11,
Hving been through a disastrous, and expensive issue with the transmission and drive shaft that began with "funny noises" I suggest you get this car up on a lift ASAP and check out all transmission mounts, all bolts on the drive shaft and everything in and around this area.
