Seems like different suppliers are suppling different shades of the original colors these days. When the colors of the controls are not exactly correct I also re-use the original plastic part of the controls. It adds a lot of time to the job and can be tedious to change the new rubber part of the controls to the original plastic. In addition you must be very careful to keep from cracking the delicate thin plastic, when riveting the rubber parts in place. Removing the old tiny brass rivets also is tedious. I found some nice hollow brass rivets to use, just like the originals, you must be sure to have them flush when installed or they may snag on the metal control frame. If you have the early hard solid plastic controls like pj, you do not have to worry about these problems.
