Author Topic: Chassis / Frame Dimensions  (Read 4745 times)
PeterPortugal
  • Portugal, Faro, Lagoa
« on: September 05, 2019, 12:05:25 »
Hi All,
I bought a Tru-Way frame dimension chart for 1963 220b, 220Sb and 220Seb models.
Does anybody know if this is also suitable for the 220se coupe and cabrio?
I wanted to check some dimensions and the first one I took was between the bolt centres which locate the front leaf springs. According to the diagram this should be 750mm (375mm from each bolt centre to the car centerline). When I measured mine it was an inch wider (775mm)
I would be VERY grateful if anybody out there with a Coupe or Cabrio could measure and confirm the distance on their vehicle.
Regards
1963 220se Cabrio
1968 280se Coupe
PeterPortugal
Re: Chassis / Frame Dimensions
« Reply #1 on: September 29, 2019, 18:32:23 »
Hi All,
Just giving this one a push.
Regards
1963 220se Cabrio
1968 280se Coupe
« Reply #2 on: September 30, 2019, 04:59:32 »
These specs are also available in The MB Factory Technical Data Manuals.
PeterPortugal
« Reply #3 on: September 30, 2019, 09:45:58 »
Hi Joe,
Thanks as always for finding the time to reply. If this is what people refer to as the BBB I do have an electronic copy but cannot find this information listed. If anybody has a BBB with the chassis dimension details for a W111 220SE/C please could you PM me?
Regards
1963 220se Cabrio
1968 280se Coupe
DaveB
« Reply #4 on: September 30, 2019, 11:15:08 »
I have one of those books and Joe is right, the information is there: 382 ± 1 mm for 220 SEB/C. Obviously this is still narrower than yours so that's a little puzzling.
The book states 375 mm  ± 1 mm for 220 B, SB, SEB 1st version
The book is not the BBB, it's much smaller and contains only specifications, not procedures.
DaveB
'65 US 230sl 4-speed, DB190
PeterPortugal
« Reply #5 on: September 30, 2019, 13:25:35 »
Dave,
Thanks a lot mate, you have just made my day. The reference I had said 375mm +/-1mm.
382mm +/-1mm certainly swings it back in my favour. If I measure it real carefully I might just about creep in to that.
I will be looking for one of these manuals if anybody has one for sale.
Regards
1963 220se Cabrio
1968 280se Coupe
PeterPortugal
« Reply #6 on: September 30, 2019, 14:44:31 »
Are we talking about this book??
1963 220se Cabrio
1968 280se Coupe
« Reply #7 on: September 30, 2019, 14:47:43 »
These Booklets are often found on Ebay. Be sure to get the correct one since they were published almost every year or two for the different models. There is an electronic file around somewhere that someone made of one of these. Might be in the our Technical Manual?
« Reply #8 on: September 30, 2019, 14:48:29 »
Yes that is the book!
PeterPortugal
« Reply #9 on: September 30, 2019, 15:03:47 »
Good job......I have just paid 180 USD for it !!
1963 220se Cabrio
1968 280se Coupe
« Reply #10 on: September 30, 2019, 21:00:24 »
Ouch! seems a bit expensive.
PeterPortugal
« Reply #11 on: October 02, 2019, 12:03:59 »
Everything associated with these cars is a bit expensive !
On the technical front does anybody know the correct method to determine the centre line of the car? The frame dimensions are referenced to this. It would be possible therefore to have the correct distance between the bolts (which is what I was measuring) but unequal values for the two sides with respect to bolt to centre line, meaning the chassis is not straight.
1963 220se Cabrio
1968 280se Coupe
