Author Topic: Removing the brass bushings from the king pin assy  (Read 2806 times)
CJHenderson
  • USA, AR, Benton
« on: September 18, 2019, 00:45:23 »
The brass bushings on the king pin assembly are worn out. My question is, how do you drive them out.
1950 MG-TD
Re: Removing the brass bushings from the king pin assy
« Reply #1 on: September 18, 2019, 05:14:01 »
Those brass alloy bushing are pressed into the steering spindle and are not that easy to remove. Once you get one side out the other can be pushed out easily enough but getting the first one out is the harder part. I've used a tap and cut threads into the bushing and then I pushed it out using the tap as a mandrel. Kind of unorthodox but it works.
« Reply #2 on: September 18, 2019, 14:19:16 »
Here is Dan’s method in action.
https://m.youtube.com/watch?v=77UXeqlK6nY
« Reply #3 on: September 18, 2019, 16:34:13 »
Bring the pin and the knuckle to an  automotive machine shop and have it done.  After the bushings are installed they need to he honed to size anyway so you might as well have them spend a few minutes and press the bushings in.
« Reply #4 on: September 18, 2019, 17:50:09 »
That's the way to do it. The bushings will slide over the new king pins before installation but not after they're pressed into place. They actually shrink that much.
CJHenderson
  • USA, AR, Benton
« Reply #5 on: October 22, 2019, 21:20:44 »
What size tap to use?
1950 MG-TD
