I will check it out Tyler; I had originally tried a 33Ω resistor and measured about 9V; I think with the 47Ω resistor I should be somewhere between 7.5 - 8.5V, but I didn't actually measure it since I only used the resistor only to check if the car started and revved up normally, which it did. All the mileage I have done was without ballast resistor.
