Author Topic: Headlight glass. Flat or rounded?  (Read 2851 times)
Paul99
  • United Kingdom, England, Hampshire UK
  • 230 SL White. 1966.
« on: September 22, 2019, 15:49:11 »
I have seen a couple of pagoda where the headlight glass is flat Vs mine which are curved.  Not the USA type sealed beam ones. The standard euro ones.
Which is correct and did they change over the years ?
Re: Headlight glass. Flat or rounded?
« Reply #1 on: September 22, 2019, 16:06:08 »
The flat glass style was used in the halogen fixtures that had 2 separate halogen bulbs. If your fixture uses a single headlamp bulb incorporating 2 filaments (low and high) then the curved lens is the correct one.
https://www.sl113.org/wiki/Electrical/EuropeanLamp
« Reply #2 on: September 22, 2019, 19:55:49 »
I prefer the rounded ones anyway. They're much stronger and won't break as easily as flat glass.
Paul99
« Reply #3 on: September 23, 2019, 13:33:35 »
Great thanks. Mine are rounded as it's a 1965/6 built car. Looks correct.
Another question. When you replace the standard bulbs for halogen brighter bulbs do you remove the silver shades that sit in front of the old bulbs or keep them in place?
« Reply #4 on: September 23, 2019, 13:41:58 »
Paul,
Suggest you fit LED’s, they are really twice as good as the originals and far better than halegon.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Guanaja
  • USA, NM, Albuquerque
« Reply #5 on: September 23, 2019, 20:56:03 »
 RE LED headlight bulbs, can you provide more detail, brand or model number for the bulb?  Is this a direct replacement or require further modifications?
« Reply #6 on: September 23, 2019, 21:24:41 »
I don’t have the details with me, search on LED headlights, there was some discussion recently and have a read through this post here for others.
https://www.sl113.org/forums/index.php?topic=22863.msg183730#msg183730
They are direct replacements depending on your current ones. Some need a tag removed by file.
