Author Topic: what color for the coolant tank ?  (Read 4172 times)
yves
  • France, Poitou-Charentes
« on: September 24, 2019, 06:58:03 »
I want to renew the coolant  tank  paint  and wonder if it is black gloss or semi gloss ?
Thank's for your advice ... ;)
cfm65@me.com
  • Cape Town, South Africa
Re: what color for the coolant tank ?
« Reply #1 on: September 24, 2019, 09:21:57 »
Black, as you can see on yours is correct.
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
hkollan
  • Spain, Castilla-La Mancha
« Reply #2 on: September 24, 2019, 10:12:32 »
It’s semi gloss/satin black
Hans K
Hans K, Cuenca, Spain
yves
« Reply #3 on: September 24, 2019, 10:20:53 »
Thank's  i'll use 1/2 gloss
« Reply #4 on: September 24, 2019, 13:12:35 »
Semi.  New straps available from Mercedes for a few dollars. If your cap says “100” on it it is correct original and should be yellow zinc plated.
« Last Edit: September 24, 2019, 13:17:58 by Shvegel »
yves
« Reply #5 on: September 28, 2019, 20:50:13 »
Job done with satin black paint after bead blasting in my "diy" congelator bead blasting cabinet  ;)
« Last Edit: September 28, 2019, 20:59:56 by yves »
« Reply #6 on: September 28, 2019, 21:21:28 »
This cabinet is fantastic!
I think I need to buy my wife another freezer in case the current one goes bad. Freezer is very important in a household, isn't it?
« Reply #7 on: September 28, 2019, 21:34:05 »
How do you control the dust that's part of blasting? I don't see any sort of vacuum cleaner.
yves
« Reply #8 on: September 29, 2019, 06:27:52 »
Hi Doctor B , i have a vacuum exit on one side where i plug a vacuum cleaner:
At the Bottom, the balls of sanding go in a plastic basket that i can slide on one side , so i can filter the paint résidus through a strainer and put back the basket Under the wood planks .
I have removed the grill upon the basket because the vacuum pipe needs to be modifyed in its position to avoid  sucking only the air . The next thing i have to do is to fit a V Bottom in the basket so the balls will Always go to the vacuum hose
I have fitted two lights  and the glass on the top can be easily removed when it is too much "sand blasted"
« Last Edit: September 29, 2019, 06:48:23 by yves »
MikeSimon
  • USA, OH, North Royalton
« Reply #9 on: September 29, 2019, 19:32:36 »
Very nice cabinet! Fortunately, we have "Eastwood" stores here in the U.S. where you can buy blast cabinets for really cheap... 8) ;D ;D ;D
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #10 on: September 30, 2019, 04:40:46 »
It seems that in the US you have a great variety of supply of tools and materials for DYI everything. Including opportunity to rent tools...
My wife works with interior decorations and garden - it is amazing what you get in the US. Same goes for weekend mechanics.
« Reply #11 on: September 30, 2019, 18:51:33 »
That's a really nice cabinet.  Much larger than most of the ready made ones.
boterinse9
  • USA, IL, marengo
« Reply #12 on: February 09, 2020, 03:34:04 »
I cleaned all the paint off  buffed the hell out of it now have a beautiful brass tank  My Q/ is  when did MB change from  whatever the  tank was made of  to a brass tank I have found anything on it yet  Who knows???
1970 280 SL Silver Automatic
1976 300D White
2012 C300 4matic
2004 chevy Silverado
WRe
« Reply #13 on: February 09, 2020, 07:59:42 »
Merveilleux!
...WRe
« Reply #14 on: February 09, 2020, 09:55:21 »
There are many shades of black. That is why it is better to give the color code: its satin black RAL 9005.
yves
« Reply #15 on: February 09, 2020, 11:01:19 »
Shades of grey Too….! :-X
« Reply #16 on: February 10, 2020, 01:22:10 »
If anyone intends to do a lot of sand, bead, or walnut blasting. A Dust Deputy or equivalent is a must have. It catches most of the spoils before it hits the filter in your shopvac. Was definitely worth it.
winston the browndog
« Reply #17 on: February 10, 2020, 03:44:59 »
Does anybody know the part # for the straps ? I have a number of 900288122101 , but it is NLA.
 Thanks , Paul
« Reply #18 on: February 10, 2020, 10:01:54 »
N 900288 122101 it is.
They are available in Europe. May try the Classic Center in the US...
WRe
« Reply #19 on: February 10, 2020, 11:10:42 »
...WRe
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #20 on: February 10, 2020, 11:29:28 »
They "were" available last week.  I just bought the last 2 clamps from a San Diego MB dealer. They had to transfer them from New Jersey. I'm sure they can order from Germany now.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
