Author Topic: Anyone put their car together from a bare shell?  (Read 3842 times)
« on: September 26, 2019, 09:34:57 »
I am about to put the under dash area back together and the problem I have is I didn't take it apart.  I am wondering if anyone has a rough outline as to the order things go back together?  I figure the firewall pads then Wiper linkage and then heater box but wanted to be sure before I end up messing up and having to backtrack.
« Last Edit: September 27, 2019, 16:48:04 by Shvegel »
mercakungen
  • Finland, Central Finland, Porvoo
Re: Anyone put there car together from a bare shell?
« Reply #1 on: September 26, 2019, 10:07:22 »
That order worked on my project.
BR,
Matti
-70 280SL
-57 Continental MK II
-70 Plymouth AAR Cuda
ex:
-61 220SEb Coupe "Kompressor"
-61 VW Karmann Ghia Coupe
-53 VW T1 "Zwitter"
Dave H
  • United Kingdom, England, Durham
    • Dave H
« Reply #2 on: September 26, 2019, 10:43:07 »
Just been doing the same thing the past couple of weeks.
That is the order i did.
Next i refitted the wiring loom, heater blower, heater cables/ fresh air flap, washer hose routed through dash, steering box and column.
( note the cardboard demister vent above the column should go in before the column. I forgot to but intend to rectify this next time i go in the garage.
« Last Edit: September 26, 2019, 11:02:43 by Dave H »
Mercedes 250SL    1967
Mercedes 250SLK  2014
Alfa Romeo 166 3.2 Ti
Fiat 500
doitwright
  • USA, IL, Willowbrook
« Reply #3 on: September 26, 2019, 18:16:32 »
Are you installing a new firewall grommet on your wiring harness? I have a trick for doing that without removal of any connectors on the harness.
Frank Koronkiewicz
Willowbrook, Illinois
dirkbalter
  • USA, CA, Corona
« Reply #4 on: September 26, 2019, 18:39:25 »
Frank,
please share it.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
EeVeeWee
« Reply #5 on: September 26, 2019, 19:06:05 »
I still have to do it, so tips ar welcome.  ;D
Again something else.
johnk
  • USA, OH, Avon
« Reply #6 on: September 27, 2019, 02:32:10 »
I am starting the same process right now so this list is extremely helpful thanks?
John
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #7 on: September 27, 2019, 02:38:11 »
Thanks everyone for chiming in.
Waltklatt, Wow.  Sounds like you have done this a time or two.  Thanks for detailed checklist.
« Reply #8 on: September 27, 2019, 15:56:04 »
That reminds me to order a little MBtex.
doitwright
Re: Anyone put their car together from a bare shell?
« Reply #9 on: September 27, 2019, 22:19:35 »
Since a few have asked for my tips on replacing the firewall grommet, I will create a separate post under the electrical section. I will put a description and link to my google photo album there. Before you start, you will need to get a 1-1/2" and 1-1/4" sink "tail piece" from your hardware or home improvement store.
Frank Koronkiewicz
Jack Jones
  • Canada, ON, Milton
« Reply #10 on: September 28, 2019, 01:09:43 »
I am at the same point on my car so I appreciate any and all input.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
