Author Topic: Front Brake Calipers  (Read 3180 times)
Harry
  • USA, TN, Knoxville
« on: September 26, 2019, 22:52:21 »
Geez.  My 1966 230SL has Girling calipers.  I find a lot of dialogue on switching to ATE and I'm not opposed to doing that.  But if I go re-manufactured,  my Girling Core probably won't suffice as exchange for the ATE?  Where can you find the ATEs?  I've looked on Rock Auto but don't see those.
Or, where can I get the rebuild kit for the Girlings?
Many thanks,
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Front Brake Calipers
« Reply #1 on: September 26, 2019, 23:18:32 »
Check out AutohauzAZ.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
ggdtr5
  • United Kingdom, Scotland, Aberdeenshire
« Reply #2 on: September 27, 2019, 08:10:31 »
I bought ATE calipers from eBay about £80 - outright purchase no exchange.
Regards Graham
1971 280 SL
1972 Triumph TR6
1979 mini pick up
1992 Mini Cooper
1949 TED Ferguson tractor
2002 Honda S2000
2002 Honda S2000
« Reply #3 on: September 27, 2019, 12:11:58 »
Your local auto part store probably won't care as long as they get a caliper back. Besides, the core charge is usually pretty nominal.
Also there is a company that rebuilds and restores calipers for older cars called PMB performance.  They restore calipers as well as sell parts.
https://www.pmbperformance.com/brake-calipers.html
mrfatboy
    • Mrfatboy
« Reply #4 on: September 27, 2019, 12:21:26 »
Here is another company you might want to check out for a caliper rebuild.
https://whitepost.com/
Signal Red
4 Speed
Harry
« Reply #5 on: September 27, 2019, 12:33:39 »
All - thanks very much.  I pulled a piston out of one of the calipers last night and this would be more than a standard rebuild.  There is a lot of rust and pitting, and I'm not sure these can even be rebuilt without machining - which would quickly become more expensive than replacing.  I'm leaning towards just biting the bullet and buying the new ATEs.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
« Reply #6 on: September 27, 2019, 16:05:47 »
I am restoring my car and I started down the road to restore my calipers but decided to just replace them all.  It was an ouch but I probably never have to think about them again.
Mike K
« Reply #7 on: September 28, 2019, 06:53:28 »
Same here, bit the bullet and replaced the calipers. While I was at it, installed new booster, new master cylinder, replaced rubber hoses with stainless steel braided brake hoses, new rotors, and new brake shoes at rear -any and all issues solved!
This should outlive me...
Mike
