with our official
Pagoda SL Group logo
from our official partner.
testing early fuel injection pump thermostat
Topic: testing early fuel injection pump thermostat (Read 1915 times)
mnahon
Full Member
Silver
Canada, QC, Montreal
October 01, 2019, 03:01:11 »
It seems that the (tall) thermostat on the early 230SL fuel injection pump can be tested by placing in boiling water to see if the pin extends. Does anyone know how much it should extend?
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
Associate Member
Platinum
Canada, ON, Port Lambton
Re: testing early fuel injection pump thermostat
October 01, 2019, 06:35:22 »
It only moves about 1.2 mm on a 230SL but you have a 280SL so it uses a different thermostat. The one on a 280 moves a lot more - maybe 7 -8 mm.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #2 on:
October 01, 2019, 09:19:00 »
The new thermostat (new style) I bought from MB two months ago extended exactly 7mm. The old one I had only 5mm.
mnahon
Full Member
Silver
Reply #3 on:
October 01, 2019, 17:55:28 »
Thanks Dan, Pawel,
I've added this information to the Technical Manual on the WRD page:
https://www.sl113.org/wiki/Engine/WarmRunningDevice
I added the following text:
The central pin of the "heat feeler", or thermostat, extends to adjust the mixture as the coolant temperature increases. The thermostat can be tested by placing it in hot water and measuring the pin's extension. The thermostat of the early 230SL looks very different from the one in later Pagodas (picture below shows the later thermostat); and it is much more expensive if you can even find it. The pin on the early thermostat should extend about 2 mm when tested in hot water, while the one on the later thermostat extends by about 7 mm.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
