Author Topic: seat springs  (Read 2318 times)
seat springs
« on: October 04, 2019, 04:05:55 »
Can someone please recommend an upholstery shop that can replace worn springs.  My driver seat is not as firm as the less used passenger seat.  Thanks!
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: seat springs
« Reply #1 on: October 04, 2019, 04:13:08 »
Try reinforcing with pool noodle.  Works well.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Re: seat springs
« Reply #2 on: October 04, 2019, 14:23:19 »
I wish I had taken some photos of my process but alas, I did not.
There are two separate and distinct kinds of springs in our seats.
The first is the zig-zag style, also known in the industry as "no sag" springs. See photo, though I don't know if the dimensions match ours, but the pattern is identical. These springs are affixed to the seat frame by spot welding. They come in a number of different dimensions and duties. Mine were all fine, so what I did was double up on the springs and used hog rings and a crimping tool to bolster the effectiveness of the existing springs. I doubled up on all of them and even added two at a cross ways bias. Using my hand pressure as a crude gauge, it felt like I had added quite a bit of stiffness to the overall springing. No; it was all an illusion.
The other spring is the flat spring, and these are custom to this seat.
Despite my laborious effort in adding stiffer and more springing with the zig zag, the effect of all my labor was about nil. The seat still totally bottomed out even with my lightweight young daughter sitting on the seat in testing.
The pool noodle addition did the trick. That prevents the seat from bottoming out and damps and adds effectiveness to the springing that's there.
Re: seat springs
« Reply #3 on: October 04, 2019, 14:43:51 »
I will also be a supporter of the pool noodle inserts.
Having just driven 10,000 miles across the USA in the last 14 weeks.  I was surprised how well they worked and supported the passenger and driver.
1972 MB 280CE Auto RHD 906G
2019 Izuzu DMax 4x4 Slide-on camper.
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
