Author Topic: Horn Reassembly  (Read 2521 times)
Harry
  • USA, TN, Knoxville
Horn Reassembly
« on: October 07, 2019, 12:52:17 »
I had taken my larger horn apart to clean it up and paint it and I am now reassembling it.  There had been what appears to be a paper gasket between the back housing and the diaphragm.  I was going to make something up, and maybe coat it with vaseline or grease.  I considered a small bead of silicon but I don't want to inadvertently dampen it.  Any similar experience with these horns?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Horn Reassembly
« Reply #1 on: October 07, 2019, 13:58:08 »
I just did this job and used this material for the gaskets.  You can thank the Horn God 😈(66andblue) for the tip🤣
You can just use some sort of simple semi adhesive to keep them in place. I think I used a glue stick.
https://www.oreillyauto.com/detail/b/fel-pro-3607/chemicals---fluids-16461/gasket-makers--removers---sealers-16904/gasket-material-17772/9d08f2d95b38/fel-pro-gasket-material/3045/4303226
« Last Edit: October 07, 2019, 14:14:04 by mrfatboy »
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Harry
Re: Horn Reassembly
« Reply #2 on: October 07, 2019, 15:48:35 »
Great idea.  I'll grab some on the way home.  Thank you.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
WRe
Re: Horn Reassembly
« Reply #4 on: October 09, 2019, 15:39:56 »
A well stocked artist's supply store will carry small razor blades that fit into a compass; a compass being, for those that may have forgotten, a draftsman's tool for making circles. As I was a graphic designer by initial education I have a fine set of Kern (Swiss) compasses, and the small razors that substitute for the normal [pencil] lead that goes into the compass. Today, there are also a number of low cost circle cutters available.
Using these two items, I cut new gaskets and punched (with a small hold punch) holes in them for the screws, and they were flawless reproductions.
Of course you can cut the stuff with a scissors, and punch holes with pointy things, and it will work. I did not use any gasket sealant.
Re: Horn Reassembly
« Reply #5 on: October 10, 2019, 21:27:45 »
Just to add a tip to Michael's suggestion, a single hole punch (see link below for a sample photo) comes in real handy for creating fastener holes when making your own gaskets.
https://www.staples.com/Staples-10573-CC-1-Hole-Punch-5-Sheet-Capacity-Silver/product_146308?cid=PS:BingPLAs:146308&ci_src=17588969&ci_sku=146308&KPID=146308&msclkid=ba33a054f8e311ce35bdfdcb59a0ec5b&utm_source=bing&utm_medium=cpc&utm_campaign=[ADL]%20[Staples]%20[Shopping]%20[Bing]%20[Dotcom]%20[Desktop]%20Top%2012K%20(Neither%20Queries)%20(High)&utm_term=4581802396536386&utm_content=[ADL]%20[Staples]%20[Shopping]%20[Bing]%20[Dotcom]%20[Desktop]%20Top%2012K%20(Neither%20Queries)%20(High)&adlclid=ADL-b5b5fe45-213f-45ed-82f5-255bbaf74780
