Author Topic: Video showing split linkage test.  (Read 5990 times)
« on: October 11, 2019, 02:13:03 »
Sorry for the delay in uploading the next video but her it is
https://youtu.be/28uD3JVbQ-I
Re: Linkage Tour
« Reply #1 on: October 11, 2019, 02:13:33 »
Re: Re: Linkage Tour
« Reply #2 on: October 11, 2019, 05:31:19 »
Thanks stick for the good video of the "split linkage test".  It could probably be on it's own thread so it is easier to find.
Re: Video showing split linkage test.
« Reply #3 on: October 11, 2019, 06:45:12 »
I think it is fantastic that you uploaded this video! I think the link should also be part of Technical Manual. It will be very helpful for a lot of Members who need to do this basic test looking for the sweet spot for idle.
Paul & Dolly
  • i Car
« Reply #4 on: October 11, 2019, 07:03:34 »
Brilliant,
So easy to understand now
As they say A picture is worth a thousand words
Thanks Stick,
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
« Reply #5 on: October 11, 2019, 07:35:52 »
Every full member can edit / add to the Technical Manual. I've added it to the page on the Linkage Tour.
WRe
« Reply #6 on: October 11, 2019, 12:05:39 »
thank you for joining this good video!
Hint to view it a little bit more comfortable:
Instructions for rotating the video, e.g. in VLC Media Player (not possible with Windows Media Player)
- Open the video in VLC Player.
- Pause it and click "Tools"> "Effects and Filters" at the top.
- In the new "Customize and Effects" menu, choose Video Effects> Geometry.
- If you enable the "Transform" checkbox, you can rotate the video in 90 degree increments.
...WRe
PeterPortugal
  • Portugal, Faro, Lagoa
« Reply #7 on: October 11, 2019, 14:44:28 »
Cheers Colin.
Extremely informative, as was testing the barometric compensator in the vacuum bag. Keep them coming !
1963 220se Cabrio
1968 280se Coupe
« Reply #8 on: October 11, 2019, 17:39:03 »
Thank you!
dirkbalter
  • USA, CA, Corona
« Reply #9 on: October 11, 2019, 18:11:27 »
Great, thank you.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
PeterPortugal
« Reply #10 on: October 11, 2019, 19:29:39 »
The other good thing is you get to listen to the engine up close That one rattles like a bag of spanners, which I now conclude is fine as Colin is looking after it. Makes me feel much better as mine sounds like that too. The top end rebuild is on hold !
1963 220se Cabrio
1968 280se Coupe
« Reply #11 on: October 11, 2019, 22:51:03 »
I think the term "split linkage test" was originally coined on this forum. So it looks like our influence at work!
