Author Topic: Server Time adjusted  (Read 1960 times)
« on: October 11, 2019, 07:40:17 »
Dear members,
the time of the server on which the Pagoda SL Group website runs has been adjusted to UTC (Coordinated Universal Time). That means that the time you see at the top left is probably no longer your home time.
You can adjust the time to match your home time by going to Profile -> Modify Profile -> Look and Layout -> Time Offset,  'Current forum time' is server time. You can add a number (negative or positive) to ensure the time you see matches your wall clock time.
Do note that UTC does not have daylight savings, so you'll need to adjust for that manually.
ejboyd5
  • Southold, NY
Re: Server Time adjusted
« Reply #1 on: October 11, 2019, 11:31:39 »
I'll just wait several weeks until we go off Daylight Saving Time and all will be back in sync.
Hans2012
  • USA, TX, Houston
« Reply #2 on: October 11, 2019, 16:05:08 »
The Pagoda is timeless, but thanks for the alert.
1971 280 SL - 268 Dark Green - Cognac Leather
