Author Topic: Torque on disc brake caliper bolts...64 230 SL.  (Read 3178 times)
Mike H
  • Australia, New South Wales, East Ballina
« on: October 12, 2019, 05:59:55 »
To  restore the front brake calipers, I split the two  halves, which are held together by 2x17mm and 2x14mm bolts, on the Girling 17/3 version 3 model. These bolts are torqued in the factory and are not meant to be separated.
Can anyone give a correct torque for 14 and 17mm bolts on reassembly.
Mike.
Re: Torque on disc brake caliper bolts...64 230 SL.
« Reply #1 on: October 12, 2019, 13:40:08 »
Here is a Metric bolt torque chart.
Determine the thread diameter, bolt class, and look up in the table.
Mike H
« Reply #2 on: October 14, 2019, 01:51:41 »
Thanks Tyler,
Regards,  Mike
johnk
  • USA, OH, Avon
« Reply #3 on: October 18, 2019, 19:54:26 »
How do you determine the bolt class?
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
EeVeeWee
« Reply #4 on: October 18, 2019, 20:15:00 »
The class number must be shown at the bolts: 8.8, 10.9, 12.9, etc.
When it's not shown, then it's worse than 8.8.
Again something else.
« Reply #5 on: October 18, 2019, 22:31:38 »
I am not sure, but you may need the black bolts, which is 12,9 class for calipers. You may want to check it...
swood1
« Reply #6 on: October 19, 2019, 20:03:17 »
The bolts on your front calipers are actually 11.9 and M8 thread, it should say this on the head.  The head size across flats on mine are 14mm if this helps.
If you have split them you need to replace the small rubber seals between the halves.
I was advised when re-assembling the calipers to the do the following which maybe of some help:-
1. Firstly, it is recommended you apply thread locker such as Loctite red on the threads before reassembly.
2. Tighten the bolts by hand just to ensure the halves match properly then torque up in two stages as specified below (you're basically torquing up the inner bolts prior to the outer):-
Fronts - if M8
Left to right, number the bolts with the nuts facing you 1-2-3-4
2-3-1-4  at 10ftlbs
then
2-3-1-4 at 26ftlbs
Rears - I believe are M7
Again numbered from left to right, 1-2-3-4
2-3-1-4 to 7ftlbs
then
2-3-14 to 17ftlbs
Hope this is helpful.  Dont hold me responsible if your brakes dont work...
