Author Topic: Fitting 280 engine in to 250sl  (Read 1703 times)
harrycovert
  • France, Midi-Pyrénées, castanet
« on: October 14, 2019, 08:08:24 »
Any one fitted a 280 engine into a 250 sl
Did you encounter any  problems ?
Thank you
Regards
cfm65@me.com
  • Cape Town, South Africa
Re: Fitting 280 engine in to 250sl
« Reply #1 on: October 14, 2019, 11:08:09 »
Harry,
I fitted a early 280SE engine in my 230SL as a temporary fix while I had the 230 engine rebuilt.
It must be a fuel injected 280 SE/SL engine out of a Pagoda or a W108 sedan (type 130 engine) which is very similar to the 250 SE/SL (type 129). In fact unless they are side by side, it would be very difficult to tell, unless you looked at the engine numbers or knew what you were looking for. I believe the last of these had electronic ignition which might make it tricky.
More experienced guys will know better and might elaborate on this.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #2 on: October 14, 2019, 14:46:38 »
Make sure to use "SL" aluminum engine supports or the engine will set too high in the engine bay and you will dent your hood!
SEB
  • Germany, Berlin, Berlin
« Reply #3 on: October 20, 2019, 09:38:02 »
If you need I have the engines M129 and M130 on my private stock. The M130 I put here in an add for sale.
Best wishes
Sebastian
Sebastian
1967 250 SL, 4 Speed, Euro spec, Tunis beige (462H),
