Author Topic: Drain Hole Under Brake Booster  (Read 3123 times)
beachbear
  • USA, HI, Kailua
« on: October 15, 2019, 02:21:36 »
While cleaning my engine bay, I came across a hole that seemed odd & out place. Looking through the forum I came across a post from 2003 that seems to describe the same thing. But there were no attached photos. There were links to an ïndex 375, but that goes to a dead end. Here is the hole I'm trying to identify. There was a rotten grommet laying on top of it, but it didn't belong there. Is it really a drain? Should it have a rubber plug?
David White
'69 280sl automatic, 3rd owner since '82
Re: Drain Hole Under Brake Booster
« Reply #1 on: October 15, 2019, 11:42:03 »
There were several threads on this hole. If I remember correctly this hole leads to an empty space between the metal sheets and the conclusion was: plug it.
Try search "drain holes" or "drain points" to check this.
« Reply #2 on: October 15, 2019, 22:39:12 »
There is another on the other side of your car. Is it plugged?
beachbear
  • USA, HI, Kailua
« Reply #3 on: October 15, 2019, 22:57:40 »
With your question, I unclamped the wire harness that runs across where that hole would be. There is a hole, plugged with a rotten plug. My clean up has not made it as far as that part of the engine bay. I found a 10mm plug at AuthenticClassics that should work to plug both of these holes. Thanks for your help.
David White
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #4 on: October 15, 2019, 23:49:59 »
Shvegel, are you talking about the plug under the wiper motor? I've never even seen the plug under the brake booster - until just now when I searched with a flashlight. thanks, charles
« Reply #5 on: October 16, 2019, 00:54:40 »
Charles,
It in the exact same location on the other side buried under the wiring harness.
beachbear,
Thanks for checking that.  Now I know there are supposed to be plugs in the holes and where the strap for the harness is located.
« Last Edit: October 16, 2019, 00:59:21 by Shvegel »
beachbear
  • USA, HI, Kailua
« Reply #6 on: October 16, 2019, 01:01:51 »
Charles, that is a GREAT picture of the plug under the brake booster. Thanks!
David White
beachbear
  • USA, HI, Kailua
« Reply #7 on: October 16, 2019, 01:06:17 »
BTW, looking at the hole underneath the wiper motor, it, the one under the brake booster and the one on the right side, under the wiring harness (on my LHD 280) appear to be the same size.
David White
Harry
  • USA, TN, Knoxville
« Reply #8 on: October 28, 2019, 16:33:04 »
I just redid my engine compartment and I didn't find this plug (1966 230SL).  I did find that there is a drain "hole", if you will, that actually is an opening in the sheet metal in this area that will permit water to drain down into the wheel well.  You can also see that from within the wheel well.  It is where the sheet metal fits against the frame on the horizontal area.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
