Author Topic: Axle shaft bearings query  (Read 3569 times)
swood1
« on: October 17, 2019, 08:42:50 »
Hi all,
I have removed both my axle shafts from the differential, just looking at the play in the bearings.  Is there a defined way to check them?  I can initiate some rocking between the inner and outer race in both bearings.  Is this normal?  I cannot see any movement vertically between the inner and outer race.
The car was a project and not running when I acquired it.
Steve
swood1
Re: Axle shaft bearings query
« Reply #1 on: October 17, 2019, 12:40:11 »
I just found some details in the Technical Manual.  I didnt realise the RH and LHS bearings were different.  This clarifies why one of my bearings was showing alot more side movement than the other.
Steve
« Reply #2 on: October 17, 2019, 15:09:17 »
Pretty much normal for the right hand side with the self aligning bearing to have a bit of end play. Not so much for the LT side.
« Reply #3 on: October 17, 2019, 15:27:08 »
Best to replace all the bearings and seals while the unit is apart and you will not have to do it again in the near future. Original brands are available from after-market resources for big savings on the parts. In any case, if you slightly pinch the bearing in a vice and rotate the axle, if bad, you will feel the bad spots in the bearing as the axle turns. Pinching the bearing in the vice simulates a load for testing the bearing when the axel is turned.
swood1
« Reply #4 on: October 17, 2019, 16:42:15 »
Thanks Joe,
I shall do some searching of the forum for the two bearing part numbers.  Out of interest do you know if the bearing seals are off the shelf items also?
Steve
« Reply #5 on: October 17, 2019, 17:25:13 »
I think they're more likely to be MB parts. Most bearing places you go to will be industrial application only and if certain pieces cross over to automotive that's incidental. Some automotive seals and bearings are propiretary so industrial and automotive operations generally steer clear of each other.
« Reply #6 on: October 17, 2019, 21:04:00 »
For instance, here is the kit for the left side...………
https://www.ebay.com/itm/1960-s-Mercedes-Rear-Axle-Bearing-Kit-108-109-110-111-113/293116552656?hash=item443f1ba5d0:g:HdwAAOSwKF1c~XfB
Order two of those kits since the seals and gaskets are the same on both sides, but use only one "ball bearing" for the left side. Get the special expensive "centering bearing" by itself.
« Last Edit: October 17, 2019, 21:19:35 by ja17 »
« Reply #7 on: October 18, 2019, 06:54:08 »
Thanks Joe,
Steve
From EPC:
A 002 981 23 01 this is left
A 000 981 05 06 this is right; this is the self-centering one (over $100 at MB)
There is quite a lot about it on our Forum:
https://www.sl113.org/forums/index.php?topic=2163.msg11244#msg11244
https://www.sl113.org/forums/index.php?topic=18315.msg128000#msg128000
UJJ
  • USA, CA, Grass Valley
« Reply #8 on: October 18, 2019, 13:46:46 »
For your Info:
The right side bearing is a spherical roller bearing "20208-TVP".
I do have an extra one made by FAG, but shipping to Europe is probably not feasible.
Just in case, I am asking $80.00 for it.
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
swood1
« Reply #9 on: October 18, 2019, 14:40:28 »
Thanks UJJ,
I have picked that up from some of the other forum posts and Pawels links.
I have asked for a quote from MB direct as I want new seals also, I can then compare costs to buying the bearings and seals seperate.  I shall let you know if I would like your bearing but I think import duty from USA would kill it :(
Steve
« Last Edit: October 18, 2019, 14:48:28 by swood1 »
dirkbalter
  • USA, CA, Corona
« Reply #10 on: October 22, 2019, 16:19:46 »
Urban,
I am interested in the bearing if still available.
Let me know.
Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
UJJ
« Reply #11 on: October 23, 2019, 13:41:12 »
Hi Dirk
yes, still available. PM me
Urban
Urban Janssen
Grass Valley, CA
173 anthracite grey
