Author Topic: Please help with relays ... 230SL 1964  (Read 2911 times)
wilediema
« on: October 17, 2019, 21:57:13 »
I am looking for relays for a 230SL from 1964
three are close to water tank (wiper)
one is close to cooler water tank
I am looking to buy but if anyone have the part numbers is fine as well.
the plug terminals pictured
https://ibb.co/nBcXjSw
https://ibb.co/gSYbb15
https://ibb.co/HFjyF3F
https://ibb.co/H4FNTZf
Re: Please help with relays ... 230SL 1964
« Reply #1 on: October 18, 2019, 05:58:06 »
The last plug photo is for the voltage regulator. The large plug is for the wiper relay which is expensive and may be hard to find. The two small plugs are the standard cold start relays and are used in many Mercedes passenger cars of the time. You might want to find these locally.
wilediema
« Reply #2 on: October 18, 2019, 06:20:57 »
Thanks ja17...
wilediema
« Reply #3 on: October 18, 2019, 07:17:34 »
 anyone help me to confirm...
wiper motor relay number is 0005426819
Cold Start Relay number is 0332008001
And how about the other two?
« Reply #4 on: October 18, 2019, 08:56:47 »
What I can see in the Mercedes system for 113042:
Wiper motor you have:
A 000 542 53 19, replaced by
A 000 542 68 19, optional with
A 000 542 61 19
It is useful to have all these numbers when you are looking for it on, e.g. ebay.
For mixture control for 113042 I have
A 000 542 45 19, replaced by
A 000 542 58 19
For cold start I see
A 001 545 16 24
Here: the system does not recognize PN 033 100 8001. In my car the relays for cold start and for FIP solenoid are the same (280SL), not sure if it applies to your car.
No relays are available at Mercedes.
Voltage regulator
A 002 154 74 06, $400-500 at Mercedes, but here we can find replacements that are less expensive, e.g. Hella - try to search "voltage regulator" on the forum.
« Last Edit: October 18, 2019, 10:55:05 by Pawel66 »
wilediema
« Reply #5 on: October 18, 2019, 19:12:47 »
Big THANKS to you Powel66
« Reply #6 on: October 18, 2019, 20:21:16 »
My pleasure.
For wiper relays we may go to: www.w113.eu
