Author Topic: Problem Removing Distributor  (Read 1924 times)
Mpgeslak
  • USA, GA, Greensboro
« on: October 19, 2019, 17:51:50 »
I am restoring my first Pagoda and have run into an issue on my first project.  I am replacing the distributor with an electronic ignition from 123.  I set the rotor to TDC for the #1 cylinder and am now trying to remove the old distributor.  I could only find one bolt on a ring type fastener just above the housing which I removed.  I am not sure if I have missed something or the distributor is frozen, but I can’t get it to move at all.  Any help would be appreciated!
teahead
  • USA, WA, Des Moines
  • aka "Rob"
Re: Problem Removing Distributor
« Reply #1 on: October 19, 2019, 17:56:34 »
what year you got?
Did you check the online technical manual here?
Mpgeslak
« Reply #2 on: October 19, 2019, 18:09:18 »
1967 250SL.  Yes, checked the technical manual but nothing specific.  Looks like it should be easy, but having a real problem with it.
« Reply #3 on: October 19, 2019, 22:27:11 »
Yes just the one bolt. Apply penetrant at the base and then try rotating it back and fourth. If that does not work, warm the aluminum mounting with a propane torch or hair drier.
Mpgeslak
« Reply #4 on: October 20, 2019, 11:26:22 »
Thanks for the advice, worked perfectly.  Was a bit nervous heating up the housing, but went at it a bit at a time and the distributor is out!!
cfm65@me.com
  • Cape Town, South Africa
« Reply #5 on: October 20, 2019, 20:05:33 »
The ‘O’ ring in the image above is often the cause of the Dizzy sticking.
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
