Author Topic: Brake Bleeding procedure - correct order?  (Read 3230 times)
Andres G
  • USA, FL, Miami
    • Toyota Adventure Team
« on: October 20, 2019, 19:42:30 »
I have just installed my rebuilt brake booster and brand new ATE replacement master brake cylinder.
I am now taking on the brake bleeding procedure and wonder which is the correct order (which caliper to do first) for a LHD 250SL?  Anyone know?
bogeyman
  • USA, NE, Omaha
Re: Brake Bleeding procedure - correct order?
« Reply #1 on: October 20, 2019, 19:55:13 »
You start from the furthest, therefore the sequence would be:
RR
LR
RF
LF
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
cfm65@me.com
  • Cape Town, South Africa
« Reply #2 on: October 20, 2019, 20:02:51 »
Yep, Andreas,
You do the one furtherest from the master, first. In other words, the right rear slave cylinder, then left rear, right front, left front, the booster, master on a LHD car. Same principle on a RHD. Start with the furtherest away from the Master.
Then do it again, rr, lr, rf, lf, booster then master.
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Andres G
  • USA, FL, Miami
« Reply #3 on: October 20, 2019, 20:33:43 »
Thanks folks.  I was beginning to worry about the time it took to bleed the RR, and I’m still getting air...
Going to switch to the LR and see what happens.  I’m using a power bleeder so not too bad a job.
I’ll circle back when I am done.
Jordan
  • Canada, ON, Jordan
« Reply #4 on: October 20, 2019, 20:59:21 »
Did you bench bleed the master before you installed it?  If you didn't I don't think you will ever get rid of the air.
Marcus
66 230SL  Euro 4 speed
Andres G
  • USA, FL, Miami
« Reply #5 on: October 21, 2019, 00:44:25 »
Jordan, can you tell me how to bench bleed the master?
I think the end result I got was excellent.  Full braking power and straight and true behavior. However it is always worthwhile knowing that I did the full procedure right.
Andres
« Reply #6 on: October 21, 2019, 03:02:30 »
It helps to bleed the master first but I rarely ever do and it still works. Sometimes I've found that I had to bleed the front ones first before I could get the back ones to bleed correctly. Given that we have two separate systems that aren't connected to each other except at the master cylinder storage tank, I don't think it matters as much as one would think.
Mike K
    • Mike Kirkinis
« Reply #7 on: October 26, 2019, 06:37:10 »
Andres, here's a link with a pic of my set up to bench bleed the master cylinder.
I recommend doing it, it's very straightforward.
https://www.sl113.org/forums/index.php?topic=22964.msg164235#msg164235
best,
Mike
http://michali.zenfolio.com
  • USA, WI, Mequon
« Reply #8 on: October 26, 2019, 12:52:27 »
Sometimes, what looks like air in the lines, is air being sucked in past the open bleeder screw.  It looks like you never get the air out.  You can sort of test it by opening the bleeder further or closing it somewhat while bleeding.  If the character of the bubbles changes that is likely the issue.  You then use your judgment to determine if the line is free of air, close it up, and eventually test the pedal and brakes to verify.
I don't bleed the master in the normal course of bleeding, seems to me that is accomplished through the process of bleeding the lines.  I use a power bleeder, pressure provided at the fluid reservoir.
Andres G
  • USA, FL, Miami
« Reply #9 on: November 06, 2019, 22:10:47 »
Been driving it around lately and found no issues at all.  I am in love with my new brakes... Thanks for the input guys.
