Author Topic: upper and lower wishbone swing arm query  (Read 2865 times)
swood1
« on: October 22, 2019, 10:28:13 »
Hi all,
Is there a defined distance the upper and lower wishbone should be spaced relative to the nuts? and the subframe mounting.
If you look at the photos attached hopefully you will see what I mean.  The manual I have just states that the lower and upper wishbones need to rotate freely but in theory I can move the lower or the upper wishbone either left or right and it can still rotate.
Regards
Steven
Re: upper and lower wishbone swing arm query
« Reply #1 on: October 22, 2019, 13:36:20 »
These are used for minor caster dimension differences from left to right of the car. For now set them centered and even on both sides of the car. When you go in for your alignment they may need to be adjusted slightly. Most often they wont need adjustment if they are kept the same on both sides.
« Reply #2 on: October 22, 2019, 15:36:32 »
I thought that caster adjustments are done on the front sub frame mounting.
« Reply #3 on: October 22, 2019, 19:17:51 »
Dan, yes the leaf eccentrics adjust caster as well. But you adjust those together as a set to get in the ballpark.
You can then adjust the upper wishbone pivots to compensate for minor differences between left and right. Just make sure you dont put the upper and lower arms in a bind in relation to eachother
« Reply #4 on: October 22, 2019, 21:20:25 »
Yup. We're on the same page here.
