Author Topic: How to remove clutch master cylinder mounting sleeve  (Read 1326 times)
johnk
  • USA, OH, Avon
« on: October 27, 2019, 15:28:00 »
My clutch master cylinder has had a small leak so I intended to replace it while my car is in the rotisserie. Any idea how to remove the mounting sleeve that wraps around it?  There seems to be a rubber fitting between the cylinder and the mounting sleeve that I will damage if I can figure out how to separate.
I tried putting it in a vice and spinning the master cylinder with out much luck.
John k
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
