Author Topic: Subframe mounts - 280SL  (Read 2370 times)
Benz280
  • USA, NJ, Jersey City
« on: October 28, 2019, 16:44:42 »
Can anyone share the amount of time required to do Subframe mounts ( both Sides )
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Re: Subframe mounts - 280SL
« Reply #1 on: October 28, 2019, 21:02:38 »
A very experienced person can do it in 1 to 1.5 hrs each side, on a nice clean car, in good working conditions, with proper tools and lot of experience. Otherwise double the time.
« Last Edit: October 28, 2019, 21:09:54 by ja17 »
behnamlaw
« Reply #2 on: October 28, 2019, 23:15:02 »
spray and soak the bolts overnight
I say a full day leisure Saturday 9-4 with lunch and slow pace  and a cold beer at the end
if bolts are not frozen of course
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #3 on: October 29, 2019, 00:00:09 »
I found a good sized prybar helped - mine is 6' long and was enough that I could do the work myself very easily- oh yeah - make sure you are at least 5' away from another car or the wall so you can use all 5'.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
« Reply #4 on: October 29, 2019, 05:19:27 »
Yes, the pry bar is a big help as you will see!
« Reply #5 on: October 30, 2019, 17:17:40 »
On one occasion (for a member here) I found the mounts sufficiently seized in place that I had to use oxy-acetylene heat to remove them.
