Author Topic: Beige 8003 carpet trim and finish around manual stick  (Read 2798 times)
lreppond
  • USA, CA, San Leandro
« on: November 06, 2019, 23:38:40 »
I’m in the process of ordering parchment loop carpeting (beige 8003) for my 71 with a manual shift.
How were these sets originally finished off.  In the same color vinyl trim or in a contrasting shade of beige?  Also around the stick shift... is there a rubber grommet or trimmed in vinyl or what.  Top stitch or blind stitched?  I don’t have the car at my home right now so I can’t check it out in person.   I want it as close to original as I can get.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
mbzse
Re: Beige 8003 carpet trim and finish around manual stick
« Reply #1 on: November 07, 2019, 07:55:50 »
Quote from: lreppond
.../...loop carpeting (beige 8003) for my 71 with a manual shift.  How were these sets originally finished off?.../...I want it as close to original as I can get
I suggest you look at original sales literature for our W113 Pagoda cars. Nice colour renderings there to answer your queries.
If you do not have access to the printed material; perhaps you can look in Gerster's website: http://oudemercedesbrochures.nl/Engels_index.html
/Hans S
cfm65@me.com
  • Cape Town, South Africa
« Reply #2 on: November 07, 2019, 12:07:41 »
Ireppond,
There are two rubbers required to finish off the hole in the carper around the gear lever.
Nr 1 is about a 4 inch rubber ring which is sewn into the carpet. Note, if I am correct the lever is not exactly in the middle of the tunnel, it is slightly over to the left.
Nr2 is a rubber boot that fits over the gear lever and into the rubber ring discussed above.
Regards
Chris
The part numbers below are from SLS( Artikelnummer 268075 and 226007)
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Bill Sgro
  • USA, FL, Bradenton
« Reply #3 on: November 18, 2019, 01:57:40 »
Is that round carpet rubber grommet still available?  I have an automatic and would love to get my hands on one if they are out there.
1970 300SEL 3.5
« Reply #4 on: November 18, 2019, 03:47:26 »
Bill,
the round rubber grommet is still available (https://www.authenticclassics.com/RUBBER-GROMMET-CARPET-AT-SHIFTER-230SL-250SL-280SL-p/auth-005155.htm)
but it does not fit around an automatic shifter console.
