Author Topic: Rear Springs  (Read 2030 times)
getsmart
  • Australia, Victoria, Dromana
Rear Springs
« on: November 13, 2019, 08:38:25 »
Hi All,
Does anyone have a set of rear springs at hand?
I'm wanting to know if the rear springs have the same top and bottom treatment/ends as the front springs? The bottom winding ends in a straight edge.
I've attached a pic of the front springs as an example. If someone has pics of the top and bottom of the rear springs that would be appreciated.
Rgds, Joe
PS. I've also attached a pic of the rear spring retainer - hopefully its the correct one as an example and I'm aware of the top and bottom rubber mounts
« Last Edit: November 13, 2019, 08:50:25 by getsmart »
Finding the red car
1964 230sl Restoration Project
dirkbalter
  • USA, CA, Corona
Re: Rear Springs
« Reply #1 on: November 13, 2019, 15:33:20 »
Joe,
My rear springs are in a shelf somewhere. Unless someone come answer your question prior, I will find them later and send you some pics.
Dirk
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
mbzse
Re: Rear Springs
« Reply #2 on: November 13, 2019, 15:49:01 »
Rear springs W113 Pagoda
/Hans S
Re: Rear Springs
« Reply #3 on: November 13, 2019, 16:27:35 »
your springs should have color markings, as pictured, to indicate spring pad sizes
getsmart
Re: Rear Springs
« Reply #4 on: November 17, 2019, 01:16:09 »
Thanks all for the quick replies  :)
Finding the red car
